Select External Not working.
I have created a form that requires "select external" set up. For some reason the drop downs keep showing up as blanks. Can someone please point me in the right direction.
Thank you James!
In this case, it appears that the language was not completely applied in the form - the default language was set and the external choices had a label::English (en) column, but the rest of the form did not. If you plan on having a multi-lingual form, it's best to have all columns displaying user text marked in which language they are for.
Hi Ismael,
I also have problem with external choices list. I've already checked everything I could think of, but it's just not working. Is there any way I could send you my file to your email address?
Thank you!
Dear Ismael,
Funny thing is, I had the same issue a few weeks ago and had to add ::English (en) to the word label to get it to work properly (same issue as current one). Is there a bug in the system?
Hi. I replaced the column header label::English (en) with just label in the external_choices worksheet and the external select started working.
