I have a Spatial view of a relationship between a not spatial table and a feature class. I was able to get the to join based on the correct field. I had a number of discrepancies between the two tables so i start editing the tables as need so the data would join up. It worked on my first pass through the data but then i had to do some research to fix the discrepancies. Now when i edit the data in either table its not reflected in the view. I have tried deleting and rebuilding the view a number of times with no luck. I did a spatial join in ArcMap to see if my data was line up and that worked just fine so now i am stumped. Has anyone else encountered this Problem
