Good morning.
I have a JavaScript application that uses both a dynamic map service layer and a feature layer. if I render the map, with just the feature layer, everything displays fine. However, if I add the dynamic map service layer to the map, as well, the map is pushed down on the page. If I use CSS to modify the position of the map (using negative margins), the map is almost functional, but clicking on the map generates incorrect data -- if I click on Ohio, I will get the data for a State that is more South than Ohio. I assume that this is due to the re-positioning using CSS, as this behavior is absent when I just have the feature layer on the map. Any thoughts on any of this?
Thanks...Chris
