I'm new to the python api and wanted to do some exploring to see if it would be useful for me. I downloaded everything through conda and just started playing around with the samples ESRI provided. However I cannot even get the samples to work. Is there a simple issue i am missing? #python api for arcgis
You were following the instructions etcetera in the documentation link?
From your python ide you should be able to import ArcGIS at least
<SPAN class="keyword token">import</SPAN> arcgis dir<SPAN class="punctuation token">(</SPAN>arcgis<SPAN class="punctuation token">)</SPAN> Out<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'GIS'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SpatialDataFrame'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__all__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__builtins__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__cached__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__doc__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__file__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__loader__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__name__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__package__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__path__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__spec__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>SNIP<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="string token">'plan_routes'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'raster'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'realtime'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'schematics'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'summarize_nearby'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'summarize_within'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'trace_downstream'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you Dan. That seems to have solved the problem. I didn’t have the archive open in my terminal application.
