On an Android tablet, is it possible for Survey 123 to rotate into Landscape mode as against always being in portrait. Customer's tablets are hard mounted in the vehicle cab in landscape.
Hi Roddy,
Survey123 supports landscape orientation on tablet devices. If you are not seeing this, can you provide details on the devices?
Hi James. I have uploaded a survey and I'm currently working in the offline mode in a Lenovo Yoga Tab 3 8'' and do not have this capability. Could you please provide more info on what could be happening?Thank you!
I realize that this is an old thread, but I'm having a similar issue on a newer device.
We have Trimble TSC5s that are designed with integrated keyboards to be used in landscape mode, but Survey123 only opens in Portrait mode. Is there a way to trick Survey123 into working? Or a way to add landscape support for TSC5s?
Thanks for any help!
We started seeing this today on a Tab Active 8 inch too. I thought it used to work. @JamesTedrick
We found this workaround
In settings search for "Landscape" and then in the Advanced Features overrite Portrail Only mode for the 123 appThen in settings go to "Apps" on the left side of the page, go to the 123 app and then change the "App aspect ratio" to full screen
