So I'm having an issue where I'm trying to automate publishing a feature service to AGO using python where it's failing at the analyze during StageService_server ([{"code":"00129","message":"Map has layers that record Editor Tracking dates in database time zone, but time zone has not been defined","object":"Map"}]).
The layers successfully publish using ArcGIS Pro 2.4 when setting the Date Field configuration to the appropriate time zone (as I'm using database time).
I'm assuming there is no Date Field configuration with CreateWebLayerSDDraft as it's not in the documentation. Am I missing something? Is there a work around that anyone knows about?
I'm messing around with the sddraft configuration and setting
<PropertySetProperty xsi:type='typens:PropertySetProperty'><Key>hasEditorTrackingDatesInDbTimezone</Key><Value xsi:type='xs:string'>true</Value></PropertySetProperty>
Doesn't seem to help
