I have a survey widget inside experience builder and I want to bind the survey to existing features, so when the survey is filled out it attaches to the existing record, not just create a new record (works in Survey123 field app). Along with that is it possible to change an existing field to a default answer once a survey is submitted? For instance in experience builder I chose a park, fill out the survey attached to that park record and once I submit the survey a default answer is automatically written one of my fields, so the record cannot be overwritten because I have a constraint on that field. Clear as mud? any help is appreciated. Thanks!
