We are experiencing an issue with the latest version of ARCGIS maps for Power BI (downloaded via the Microsoft Store) where we specify a color value and a size value, however when we select the map theme the "Size & Color" map theme can't be selected (it's visible but can't be clicked). The desired outcome is that when this is selected, we can select the "Symbol Style" and be able to set the individual colors for each category value returned - which was functionality that worked with this same dataset and visualisation in an earlier version.
The value for the color is a calculated measure that returns a text value, however we have also tested with a standard category field without success.
