If this has been addressed in previous post, I apologize.
Is there an issue with applying the grid theme to a repeat? I have a survey that uses a grid theme, but fails when I try to apply it to a repeat; it collapses on itself and only shows a small part of the question with the garbage can, repeat count, and + at the bottom (see image below). Everything works great til I change the width of a question, then the collapse happens. Is this a known bug/limitation of the grid theme?
Hope the UC is going well. Will be there next year.
Chris Anderson
Florida Fish and Wildlife Commission
