I'm following the instructions on how to create assignments from existing features. I uploaded a shapefile to the dispatcher map. After saving the map and opening the project and using the box to select the features nothing is selected. When I click on a feature nothing is selected.
Also, in the dispatcher map configuration I can click on a point and see a popup. In the dispatcher screen I cannot click on a point and see the popup. Is this normal behavior?
Update: Under the "Tip: Create multiple assignments at once" it says to Click + Assignments and gives 3 methods. The 3rd method, use the Identify tool, is faded out and says "Identify is disabled while editing assignments"
Update 2: Using a hosted feature service works. I thought that uploading a shapefile essentially turns it into a feature service.
