I am the owner of the hosted service for which I run a feature report for one record on survey123.arcgis.com. The report uses a custom Word template and when I generate the report, it is created nicely (with photos). I asked one of our admins to run the same report using the same template on the same OID and he can also run it fine. However, none of the field surveyors who are the ones submitting the surveys and who are in the AGOL group, can generate the same report using the same template with the same OID. Attached to this question is the long error message they receive when trying to run a report. Is this an ownership issue?
Hi Amy,
It looks like the error is related to access to the web map that is being referenced by the webmap item id for the feature report mapSettings parameter.
Can you ensure that the web map is accessible to the Group as well?
Best,
Brandon
Thank you Brandon! Yes, that was it. Oops. Error message resolved once web map was shared to the group.
