What I'm working on is modifying Robert's Identify Widget and adding the functionality of esri's Add Data widget. The purpose is to be able to upload a shapefile/kml/etc and then pass it on to be queried and generate a table and all that using the Identify Widget. We already have the Identify Widget running and I've added a button to that which exports it's results (shamelessly copies it's outputted list and reconfigures it) to a new window with some added functionality, but I'm working on adding the shapefile upload abilities.
I've added a listener to the Identify widget to listen for any layer add events and then run a new function which grabs the geometry from the added layer to pass into the rest of the Identify widget.
