#Make a separate raster *.img file for each dimension value (time) in a netcdf file import arcpy, os, time, datetime, calendar from arcpy import env from arcpy.sa import * # Input data source #########Change folder arcpy.env.workspace = "S:/PM_data/Climate_Idaho/Raw/tmmx" # Change folder++ ######### arcpy.env.overwriteOutput = True arcpy.env.scratchWorkspace = "S:/Work/Risa/Trials_Errors/ScratchWorkSpace" # Loop through a list of files in the workspace NetCDFfiles = arcpy.ListFiles("*.nc") for filename in NetCDFfiles: print("Processing: " + filename) # Set local variables inNetCDF = arcpy.env.workspace + "/" + filename #########Change the variable variable = "air_temperature" ######### XDimension = "lon" YDimension = "lat" bandDimension = "" dimensionValues = "day " valueSelectionMethod = "BY_VALUE" #########Change the variable ### InMemory_netcdf_raster = "air_temperature" ######### #########Change folder outRasterFolder = "S:/PM_data/Climate_Idaho/Output/tmmx_raster" ######### #Global Attribute: #ncFP = arcpy.NetCDFFileProperties(inNetCDF) #ncDim = ncFP.getDimensions() #Get Global Attribues #ncAttributeNames = ncFP.getAttributeNames("") #for ncAttributeName in ncAttributeNames: #print " " #print "Attribute Name: %s " % ncAttributeName #print ncFP.getAttributeValue("", ncAttributeName) #print " " #Year info #######change the lengths fileroot = filename[5:(len(filename)-3)] #change the name lengths too ####### Yr = int(fileroot) print "Processing --> " + str(Yr) #Month info allmnths = range(1,13) for mnths in allmnths: Lastday = calendar.monthrange(Yr, mnths)[1] MRange = range(1,Lastday+1) for dyy in MRange: dyys =int(dyy) mnthsss = int(mnths) a = str(mnthsss)+ "/" + str(dyys) +"/" + str(Yr) #IF Days or Months less than 10, we want to put zero at the front so it is easier to sort. if mnthsss < 10: b = str(Yr)+ "_" + "0" + str(mnthsss)+ "_" + "0" + str(dyys) else: b = str(Yr)+ "_" + str(mnthsss)+ "_" + str(dyys) if dyys < 10: b = str(Yr)+ "_" + "0" + str(mnthsss)+ "_" + "0" + str(dyys) else: b = str(Yr)+ "_" + "0" + str(mnthsss)+ "_" + str(dyys) ############## ####### ####### ####### ####### ####### ####### ####### #the OUTPUT has zero in front of October, Nov, and DEc (month value >10) #NEED TO FIX THIS *** ############## ####### ####### ####### ####### ####### ####### ####### dimensionValues = "day " + a ##########CHANGE the word too## ################# outTIFF = outRasterFolder + "/" + "tmmx_" + b + ".tif" ################# # Execute MakeNetCDFRasterLayer arcpy.MakeNetCDFRasterLayer_md(inNetCDF, variable, XDimension, YDimension, InMemory_netcdf_raster, bandDimension, dimensionValues, valueSelectionMethod) #print "Created NetCDF Layer for " + a # Process: Copy Raster arcpy.CopyRaster_management(InMemory_netcdf_raster, outTIFF, "", "", "", "NONE", "NONE", "") print "Created Raster for _tmmx_" + b ################# print "\nEnd of processing ... YAHOO!!!"
Thank you! I meant to write earlier that this script idea worked like a charm. I used an inner loop with Select by Dimension to evaluate each month in each netcdf file. I noticed you had a different method elsewhere in this thread. I'll try that next time.Thanks again,PamPS - I can't find the 'green checkmark' that is supposed to indicate this answered my question so I'll just say, "This answered my question!".
This type of task is very common in GIS work and, fortunately, requires only a very simple script. Your first step should be to read the documentation and make sure you understand what information you need to run the MakeNetCDFRasterLayer tool. Then start with this:import arcpy as ap import glob # this will give you a Python list object that you can use to batch process all of your files # just insert the path to your folder holding the netCDF files cdfList = glob.glob('C:\\examplefolder\\*.nc') # now you can loop through your list and process each file one at a time for cdf in cdfList: print "Now processing: " + cdf ap.md.MakeNetCDFRasterLayer(cdf, [fill in the other variables here]) print "Done!"Note that this is only the start of the script. For example, you'll need to make sure each output raster is given a unique, meaningful name. But we should leave some of the fun stuff for you. 🙂
This is my code. I got it to loop through every file in a folder. The problem is that it only reads the first value. I haven't figured out how to loop through each individual value in the netCDF file yet. I have been trying to modify the code from this forum: http://forums.arcgis.com/threads/32361-using-arcpy-to-export-separate-netcdf-dimension-values-as-a-raster so it reads individual value.# Import system modules import arcpy from arcpy import env from arcpy.sa import * # Input data source arcpy.env.workspace = "S:/PM_data/Climate_Idaho/Raw/pr" arcpy.env.overwriteOutput = True # Set output folder OutputFolder = "S:/PM_data/Climate_Idaho/Output/pr_raster" # Loop through a list of files in the workspace NCfiles = arcpy.ListFiles("*.nc") for filename in NCfiles: print("Processing: " + filename) inNCfiles = arcpy.env.workspace + "/" + filename fileroot = filename[0:(len(filename)-3)] TempLayerFile = "precipitation_amount" outRaster = OutputFolder + "/" + fileroot # Process: Make NetCDF Raster Layer arcpy.MakeNetCDFRasterLayer_md(inNCfiles, "precipitation_amount", "lon", "lat", TempLayerFile, "", "", "BY_VALUE") # Process: Copy Raster arcpy.CopyRaster_management(TempLayerFile, outRaster + ".tif", "", "", "", "NONE", "NONE", "") print "***DONE!!!" print arcpy.GetMessages()
# this will convert the FIRST time step in your netCDF file to a raster layer arcpy.MakeNetCDFRasterLayer_md(inNCfiles, "precipitation_amount", "lon", "lat", TempLayerFile1, "#", "TIME 0", "BY_INDEX") # this will convert the SECOND time step in your netCDF file to a raster layer arcpy.MakeNetCDFRasterLayer_md(inNCfiles, "precipitation_amount", "lon", "lat", TempLayerFile2, "#", "TIME 1", "BY_INDEX") # this will convert the THIRD time step in your netCDF file to a raster layer arcpy.MakeNetCDFRasterLayer_md(inNCfiles, "precipitation_amount", "lon", "lat", TempLayerFile3, "#", "TIME 2", "BY_INDEX") #and so on...
Have you tried right-clicking the tool and choose the 'Batch' option?
