I'm having an odd issue with the identify widget in 3.1. In my first two upgrades, this widget performs as expected. With the third nothing happens when I click on something as if it is not recognizing the layers as being present in the map. For the name I am taking it directly from the Services directory and for the field names I am using the aliases in the the services directory. Below is my widget config file. I'm not returning any errors and the main config file references IdentifyWidget_1 which is what is below. <?xml version="1.0" ?>
<configuration>
<betareturngeometryfix>false</betareturngeometryfix>
<identifylayeroption>visible</identifylayeroption>
<identifytolerance>5</identifytolerance>
<defaultzoomscale>5000</defaultzoomscale>
<keepidentifyactive>true</keepidentifyactive>
<returngeometryforzoom>false</returngeometryforzoom>
<enablelineselect>true</enablelineselect>
<enableextentselect>true</enableextentselect>
<enablepolyselect>true</enablepolyselect>
<enablemouseovergraphicsinfo>true</enablemouseovergraphicsinfo>
<enablemouseoverrecordinfo>true</enablemouseoverrecordinfo>
<usemaptime>false</usemaptime>
<infoautoclosemilliseconds>2000</infoautoclosemilliseconds>
<autoactivatedtool>mappoint</autoactivatedtool>
<excludebasemaps>true</excludebasemaps>
<labels>
<zoom2message>Click to Zoom to Point</zoom2message>
<identifylabel>Identify</identifylabel>
<resultslabel>Results</resultslabel>
<descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel>
<pointlabel>Identify by Point</pointlabel>
<linelabel>Identify by Polyline</linelabel>
<rectlabel>Identify by Rectangle</rectlabel>
<polylabel>Identify by Polygon</polylabel>
<clearlabel>Clear</clearlabel>
<loadinglabel>Loading...</loadinglabel>
</labels>
<layers onlythese="true">
<layer>
<name>Spaces</name>
<fields>
<field name="SpaceID"/>
<field name="LASTNAME" alias="Last Name"/>
<field name="FIRSTNAME" alias="First Name"/>
<field name="M" alias="Middle Initial"/>
<field name="BIRTHDATE" alias="Date of Birth" dateformat="MM/DD/YYYY"/>
<field name="DEATHDATE" alias="Date of Death" dateformat="MM/DD/YYYY"/>
<field name="Notes"/>
</fields>
<zoomscale>100</zoomscale>
<forcescale>true</forcescale>
</layer>
</layers>
<symbols>
<simplefillsymbol color="0x448ccb" alpha="0.4" style="solid">
<outline color="0x448ccb" alpha="0.8" width="2"/>
</simplefillsymbol>
<simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0">
<outline style="solid" color="0xffffff" alpha="0.8" width="1"/>
</simplemarkersymbol>
<picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0"/>
<simplelinesymbol color="0x448ccb" alpha="0.8" width="2"/>
</symbols>
</configuration>
