I am not able to publish a survey today that was working yesterday. I went to make a minor update in Survey123 Connect 2.2 and got an error; then I updated to 2.3 and received the same error:
Anyone else seeing this?
This issue should now be fixed:
https://community.esri.com/thread/198663-update-error-400-401#comment-703258
This issue appears to be fixed. Can anyone confirm resolution?
Good to know! I have both an external choice sheet and a pulldata('@geopoint', ...) function, which could both be contributing. When both are removed, a new survey will publish.
We are having the same problem with forms that use an external choice sheet, both when publishing a new survey or republishing an existing survey.
When publishing a new form, it will create the folder and feature layer, but will not produce the form.
When republishing over an existing form, the error is produced and the new form is not published. If we try to download the existing form, we get an error that the form was not downloaded. If the existing form was hyperlinked from Collector, we receive an error that the form is not downloaded on the device and trying to download the form produces an error that the form was not downloaded.
Absolutely. How can I get it to you?
Can you share the XLS file with me so that I can attempt to duplicate?
Yes, these differences are expected.
1) It's a quirk of the database & APIs we use, but we don't persist the name you supply in the form in a user-accessible fashion, so it will always come back as geometry
2) both select_one_external and select_multiple do not write the values as domains- the first because often there are more choices than we believe work well in the domain property, the second because we don't have a way to write the choices for select_multiple into the database
Yes, a pulldata('@geopoint', ...) function is used. The error was also present when I removed that calculation though.
The form did not update despite the error.
I created a new survey from the Feature Service to look for differences.
These may be expected differences?
1. my geopoint name is now "geometry", not my custom name
2. a select_one_external field is set to text, choices are missing
3. a select_multiple field is also set to text, choices are missing
Hi Braden,
Does your survey contain a pulldata('@geopoint', ...) function? As this isn't supported in the web form, the part of the API that generates the webform produces an error. It should not prevent the publishing of the form however- did the form get updated?
I failed to see this topic before submitting:
It appears to be a similar issue, code 401 publishing error.
