In a Feature Report how do I/can I, display the location of photos that are in a repeat in the Survey. I have a Survey when they open it, they are asked a few general question, then given the option to take as many photos as needed (a repeat). Each photo can have diffrent X, Y, values that differ from the survey point itself. I would like to display the photo locations in a map in the Feature Report.
Hi Benjamin
This could be achieved by adding a geopoint question to the repeat. This would make the repeat a related point feature layer (as opposed to a related table) that can store a location for each repeat record. You would then be able to show an individual map in your feature report for each photo.
Best,
Jim
Thanks for the Idea, can you provide an example of what you meen
Here I've added a geopoint question to your repeat:
Then add the ${photo_loc} placeholder to your report template (inside the repeat section). This will show the map for each repeat. If required, you could make this geopoint question read-only, so it will take the device's location and the user will not be able to open the map to modify the location. You can also use the size parameter for map questions to control the dimensions of the map (similar to photos), as well as mapSettings to use a specific web map and optionally specify a scale. More info on this here: Feature report templates—Survey123 for ArcGIS | Documentation
Hope this helps
Thank you Jim,
That worked great for a map showing each individual photo. How/can I add a overview map that shows all of the photo/geo points.
