Hi,I searched for the proper syntax to do a query like this ...xxLayer.query(where = 'objectid > 0')but instead of giving it the value (here 0) this should be a variableHow is that done?Thanks Günter
Can you try
query_result <SPAN class="operator token">=</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>query<SPAN class="punctuation token">(</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">'objectId > '</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>layer_id<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Smooth and straight. I googled, searched ... found stuff like %s, var ... but did not test the "Esri way" 🙂 Thanks!
