Is there any way to enable "Ignore SSL Errors" in Survey123 connect?
I need to connect Survey123 with Portal for ArcGIS while my current certificate is Self-signed certificate.
Ismael Chivite
James Tedrick
Thanks in advance,
Khaleel
Hi Khalil,
If your ArcGIS Enterprise is using a self-signed certificate, you can add that certificate to your devices' trust store to enable access. Alternatively, you may want to get a trusted SSL certificate for your computing environment- see Configure HTTPS using a new CA-signed certificate—ArcGIS Server Administration (Windows) | ArcGIS Enterprise
Hi Chris,
To confirm, you are able to view the Portal website without SSL error in IE/Chrome on the same computer?
James Tedrick I'm running on Windows and I installed my certificate to the Trusted Root Certification Authorities but I'm still getting the error.
Thank you James.
Khalil,
