Hallo everybody, I am using a map polygon to clip data (shape file). Both data were projected to a new coordinate reference system (WGS 84 or Ghana Meter Grid). But the clip tool is throwing an exception "empty output generated". I have checked the log file but has not identified any conflict although the system suggests extents may have to be reset. I started by projecting both data to WGS 84 before clipping but changed to Ghana Meter grid to see if the result will be different, but both gave the same error message. I also stored both in a
