I want to download data from the city's ArcGIS Hub with python and save it in a fgdb to then be loaded into sde. I have started with this tutorial - ArcGIS Hub. While I can get the feature layer with python I am having a hard time understanding how to save it to a gdb. (I have used arcpy a fair bit but I am new to this arcgis API)
from arcgis.features import FeatureLayer shoreliness_url = \ 'https://services2.arcgis.com/Ce3DhLRthdwbHlfF/arcgis/rest/services/Shorelines_Hosted/FeatureServer/0' shoreliness = FeatureLayer(shoreliness_url) # ???
Suggestions?
Sorry for the non-helpful comment, but I saw ArcGIS Hub and all I could think about was
lol - you are not exactly filling me with confidence....
url <SPAN class="operator token">=</SPAN> <SPAN class="string token">"https://services2.arcgis.com/Ce3DhLRthdwbHlfF/arcgis/rest/services/Shorelines_Hosted/FeatureServer/0"</SPAN> <SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>features <SPAN class="keyword token">import</SPAN> FeatureLayer shoreliness <SPAN class="operator token">=</SPAN> FeatureLayer<SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> f <SPAN class="keyword token">in</SPAN> shoreliness<SPAN class="punctuation token">.</SPAN>properties<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> OBJECTID PRJCTID FID_MARINE_SELECT SHORETYPE MAPSOURCE MAPACURACY MAPDATE QCSTATUS NOTES GLOBALID MARINE_ID HGUID MAPAUTH Shape__Length<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
hmmmm something amiss with your setup?
ArcGIS Pro 2.6 Beta 1 (sorry, no 2.5)
arcgis module installed in the base installation (ie, no clone)
numpy, pandas and the rest are already installed.
I didn't install geopandas, so I can't help you with the geometry
My issues are with the back-end configuration and management for organizations, particularly around caching. I won't get into the details here, but Hub had a perfectly workable, user-defined/initiated caching scheme that Esri threw out the window a while back because, well, I don't know exactly. Every "explanation" I have heard simply becomes white noise once I get a sense the product team think they know my needs better than myself.
