Where can we rename a Survey123 template? I download the RoadKill template for Survey123 and changed the items but I cannot find where to change the name of the template "RoadKill Report"?
Thanks!
Hi Warren
Open the XLSForm spreadsheet, go to the settings table and under the form_title column rename to your required form title.
Cheers
Chris
Chris Roberts Might you consider writing a Blog Post in GeoNet explaining the differences in the naming of survey forms and published surveys in Survey123? I find it very confusing.
Here's what I think I know:
Thank you,
Joe
Thanks Joe- very helpful. I'd like to see a blog post too. If you download a template and want to rename it, apparently you have to make all the changes Joe suggests above, and you still end up with all the files in the C:\Users\<name>\ArcGIS\My Survey Designs folder having the template's name.
Dake
You also have to change name of the following files:
*.gpkg
*.info
*.itemInfo
*.xlsx
*.xml
Edit forminfo.json in a text editor and change the "name" tag
