I have bus location information that is coming in daily (approx 50K of points a day) that I need to verify that the location cited is using the correct bus stop. In order to determine the nearest bus stop I was attempting to use SQL Server Spatial, but that's not as fast as I would like it to be.
I came across an older post about this (https://community.esri.com/message/939175-re-python-near-analysis-no-advanced-licence?commentID=939175&et=watches.email.thread#comment-939175) and decided that Numpy became an option and I've built the code below to compare 2 different tables and return the id from the first one, and the corresponding id/minimum distance from the second one. I've worked the code below to get me the ID of the closest stop, but I'm looking for help in making sure this is the right way to go. This is what I'm requesting:
1. When I graduated from using input test featureclasses (now remarked out) to examples of the SQL Server tables I will be hitting, I noticed that the index for the minimum distance was always off by 1 (so I just added 1 to get the right one). I'm sure something is wrong there so any help in getting the right index of the minimum distance stop would help.
2. Also, I was told that I didn't need Pandas (by Dan Patterson) but I wasn't generating lat/longs yet as this is just a piece of the overall daily processing (most of it using SQL Server) and it doesn't need to be pushed to a featureclass.
3. I came across the current way of using numpy which seems to be just a little faster than the numpy.einsum function, but maybe not if it was all cleaned up more. All opinions are welcomed as I'm interested in knowing the best way to do this.
If you can provide any help I would sure appreciate it.
<SPAN class="comment token">##Script: busStopDistances.py</SPAN>
<SPAN class="comment token">##Author: Borrowed from Dan.Patterson@carleton.ca, and others</SPAN>
<SPAN class="comment token">##Purpose: Numpy Repository stuff</SPAN>
<SPAN class="comment token">##References:</SPAN>
<SPAN class="comment token">## https://community.esri.com/thread/175646</SPAN>
<SPAN class="comment token">## https://numpy.org/doc/stable/reference/generated/numpy.einsum.html</SPAN>
<SPAN class="comment token">## https://towardsdatascience.com/how-fast-numpy-really-is-e9111df44347</SPAN>
<SPAN class="comment token">## https://en.wikipedia.org/wiki/Einstein_notation</SPAN>
<SPAN class="comment token">## https://pro.arcgis.com/en/pro-app/arcpy/data-access/tabletonumpyarray.htm</SPAN>
<SPAN class="comment token">##</SPAN>
<SPAN class="keyword token">import</SPAN> os<SPAN class="punctuation token">,</SPAN> sys
<SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> numpy<SPAN class="punctuation token">.</SPAN>lib<SPAN class="punctuation token">.</SPAN>recfunctions<SPAN class="punctuation token">,</SPAN> scipy<SPAN class="punctuation token">.</SPAN>spatial<SPAN class="punctuation token">,</SPAN> random<SPAN class="punctuation token">,</SPAN> cProfile
<SPAN class="keyword token">import</SPAN> pandas <SPAN class="keyword token">as</SPAN> pd
np<SPAN class="punctuation token">.</SPAN>set_printoptions<SPAN class="punctuation token">(</SPAN>edgeitems<SPAN class="operator token">=</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> linewidth<SPAN class="operator token">=</SPAN><SPAN class="number token">80</SPAN><SPAN class="punctuation token">,</SPAN> precision<SPAN class="operator token">=</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN> suppress<SPAN class="operator token">=</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN> threshold<SPAN class="operator token">=</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">npNear</SPAN><SPAN class="punctuation token">(</SPAN>f1<SPAN class="punctuation token">,</SPAN>f2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
f1shp_fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"DilaxID"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"LAT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LON"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># DilaxBusTest SQL Server table</SPAN>
<SPAN class="comment token">#f1shp_fields = ["OID@", "SHAPE@XY", "POINT_Y", "POINT_X"] # RandomPoints FC</SPAN>
f2shp_fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OID@"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHAPE@XY"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># Bus stop locatons FC</SPAN>
a <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>TableToNumPyArray<SPAN class="punctuation token">(</SPAN>f1<SPAN class="punctuation token">,</SPAN> f1shp_fields<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#a = arcpy.da.FeatureClassToNumPyArray(f1, f1shp_fields)</SPAN>
b <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>FeatureClassToNumPyArray<SPAN class="punctuation token">(</SPAN>f2<SPAN class="punctuation token">,</SPAN> f2shp_fields<SPAN class="punctuation token">)</SPAN>
origs <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>pd<SPAN class="punctuation token">.</SPAN>DataFrame<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'LON'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LAT'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># How do w/o Pandas?</SPAN>
<SPAN class="comment token">#origs = a['SHAPE@XY'][:] # for RandomPoints FC</SPAN>
dests <SPAN class="operator token">=</SPAN> b<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@XY'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># Distance calculations using Numpy Einsum</SPAN>
<SPAN class="comment token">## subts = origs[:,None,:] - dests</SPAN>
<SPAN class="comment token">## dist = np.sqrt(np.einsum('ijk,ijk->ij',subts,subts))</SPAN>
<SPAN class="comment token"># Distance calculations using other Numpy functions</SPAN>
P <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>add<SPAN class="punctuation token">.</SPAN>outer<SPAN class="punctuation token">(</SPAN>np<SPAN class="punctuation token">.</SPAN>sum<SPAN class="punctuation token">(</SPAN>origs<SPAN class="operator token">**</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> np<SPAN class="punctuation token">.</SPAN>sum<SPAN class="punctuation token">(</SPAN>dests<SPAN class="operator token">**</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
N <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>dot<SPAN class="punctuation token">(</SPAN>origs<SPAN class="punctuation token">,</SPAN> dests<SPAN class="punctuation token">.</SPAN>T<SPAN class="punctuation token">)</SPAN>
dist <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>sqrt<SPAN class="punctuation token">(</SPAN>P <SPAN class="operator token">-</SPAN> <SPAN class="number token">2</SPAN><SPAN class="operator token">*</SPAN>N<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># print(dist) # for testing</SPAN>
<SPAN class="comment token"># Generate output array</SPAN>
out <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>zeros<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>len<SPAN class="punctuation token">(</SPAN>dist<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
out<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> a<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'DilaxID'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># the initial table's ID field (f1, a, origs)</SPAN>
out<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>argmin<SPAN class="punctuation token">(</SPAN>dist<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="comment token"># minimum value from the distance calc</SPAN>
<SPAN class="comment token"># Adding 1 to get the correct bus stop</SPAN>
out<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>amin<SPAN class="punctuation token">(</SPAN>dist<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># minimum value's id, to be associated to later</SPAN>
<SPAN class="keyword token">return</SPAN> out
<SPAN class="keyword token">if</SPAN> __name__<SPAN class="operator token">==</SPAN><SPAN class="string token">"__main__"</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Featureclasses for testing</SPAN>
<SPAN class="comment token">#f1 = r"d:\Projects\GTFS_Update_Checker\RandomPoints.shp"</SPAN>
<SPAN class="comment token">#f2 = r"d:\Projects\GTFS_Update_Checker\Random2.shp"</SPAN>
<SPAN class="comment token"># SQL Server table/fc for testing</SPAN>
f1 <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"Ridership on W-SQL01.sde\Ridership.dbo.DilaxBusTest"</SPAN><SPAN class="punctuation token">)</SPAN>
f2 <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>r<SPAN class="string token">"GTFS on W-SQL01.sde\GTFS.dbo.BusStopsWM"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Final table for results</SPAN>
outPath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"Ridership on W-SQL01.sde\Ridership.dbo.DilaxBusDistTest"</SPAN><SPAN class="punctuation token">)</SPAN>
start <SPAN class="operator token">=</SPAN> time<SPAN class="punctuation token">.</SPAN>time<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># for determining processing time</SPAN>
out <SPAN class="operator token">=</SPAN> npNear<SPAN class="punctuation token">(</SPAN>f1<SPAN class="punctuation token">,</SPAN> f2<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Call to sub-routine for determining calculations</SPAN>
<SPAN class="comment token"># Send to output table in SQL Server</SPAN>
<SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>outPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>outPath<SPAN class="punctuation token">)</SPAN>
struct_out <SPAN class="operator token">=</SPAN> numpy<SPAN class="punctuation token">.</SPAN>core<SPAN class="punctuation token">.</SPAN>records<SPAN class="punctuation token">.</SPAN>fromarrays<SPAN class="punctuation token">(</SPAN>
out<SPAN class="punctuation token">.</SPAN>transpose<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
numpy<SPAN class="punctuation token">.</SPAN>dtype<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'dOID'</SPAN><SPAN class="punctuation token">,</SPAN> numpy<SPAN class="punctuation token">.</SPAN>int32<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'bOID'</SPAN><SPAN class="punctuation token">,</SPAN> numpy<SPAN class="punctuation token">.</SPAN>int32<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'distance'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<f8'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>NumPyArrayToTable<SPAN class="punctuation token">(</SPAN>struct_out<SPAN class="punctuation token">,</SPAN> outPath<SPAN class="punctuation token">)</SPAN>
end <SPAN class="operator token">=</SPAN> time<SPAN class="punctuation token">.</SPAN>time<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># end processing time</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>out<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>end <SPAN class="operator token">-</SPAN> start<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
