Hi Guys,
I got style loading inconsistently in ArcGIS Pro , combobox.
For example that combobox :
Loaded correctly with the following code.
<SPAN class="operator token"><</SPAN>ComboBox Background<SPAN class="operator token">=</SPAN><SPAN class="string token">"{DynamicResource Esri_BackgroundPressedBrush}"</SPAN> Foreground<SPAN class="operator token">=</SPAN><SPAN class="string token">"{DynamicResource Esri_TextStyleEmphasisBrush}"</SPAN> IsEditable<SPAN class="operator token">=</SPAN><SPAN class="string token">"False"</SPAN> Grid<SPAN class="punctuation token">.</SPAN>Row<SPAN class="operator token">=</SPAN><SPAN class="string token">"0"</SPAN> Grid<SPAN class="punctuation token">.</SPAN>Column<SPAN class="operator token">=</SPAN><SPAN class="string token">"1"</SPAN> SelectedValue<SPAN class="operator token">=</SPAN><SPAN class="string token">"{Binding Path=InputModel.Delimiter}"</SPAN> SelectedValuePath<SPAN class="operator token">=</SPAN><SPAN class="string token">"Tag"</SPAN> <SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ComboBoxItem Tag<SPAN class="operator token">=</SPAN><SPAN class="string token">","</SPAN><SPAN class="operator token">></SPAN>Comma<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBoxItem<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ComboBoxItem Tag<SPAN class="operator token">=</SPAN><SPAN class="string token">" "</SPAN><SPAN class="operator token">></SPAN>Space<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBoxItem<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ComboBoxItem Tag<SPAN class="operator token">=</SPAN><SPAN class="string token">" "</SPAN><SPAN class="operator token">></SPAN>MultiSpace<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBoxItem<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ComboBoxItem Tag<SPAN class="operator token">=</SPAN><SPAN class="string token">"\t"</SPAN><SPAN class="operator token">></SPAN>Tab<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBoxItem<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ComboBoxItem Tag<SPAN class="operator token">=</SPAN><SPAN class="string token">":"</SPAN><SPAN class="operator token">></SPAN>Colon<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBoxItem<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ComboBoxItem Tag<SPAN class="operator token">=</SPAN><SPAN class="string token">"?"</SPAN><SPAN class="operator token">></SPAN>Other<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBoxItem<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBox<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
However, If I load dynamically with style edit based on mvvm binding. with same background and foreground style. I got different result.
Grid<SPAN class="punctuation token">.</SPAN>Row<SPAN class="operator token">=</SPAN><SPAN class="string token">"8"</SPAN> Grid<SPAN class="punctuation token">.</SPAN>Column<SPAN class="operator token">=</SPAN><SPAN class="string token">"1"</SPAN> SelectedItem<SPAN class="operator token">=</SPAN><SPAN class="string token">"{Binding Path=InputModel.LongIndex, Mode=TwoWay}"</SPAN> SelectedValuePath<SPAN class="operator token">=</SPAN><SPAN class="string token">"Tag"</SPAN>
ItemsSource<SPAN class="operator token">=</SPAN><SPAN class="string token">"{Binding Path=ColumnCount, Mode=TwoWay}"</SPAN> <SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ComboBox<SPAN class="punctuation token">.</SPAN>Style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>Style TargetType<SPAN class="operator token">=</SPAN><SPAN class="string token">"{x:Type ComboBox}"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>Setter Property<SPAN class="operator token">=</SPAN><SPAN class="string token">"IsEnabled"</SPAN> Value<SPAN class="operator token">=</SPAN><SPAN class="string token">"False"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>Setter<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>Style<SPAN class="punctuation token">.</SPAN>Triggers<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>DataTrigger Binding<SPAN class="operator token">=</SPAN><SPAN class="string token">"{Binding Path=InputModel.DataReady}"</SPAN> Value<SPAN class="operator token">=</SPAN><SPAN class="string token">"True"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>Setter Property<SPAN class="operator token">=</SPAN><SPAN class="string token">"IsEnabled"</SPAN> Value<SPAN class="operator token">=</SPAN><SPAN class="string token">"True"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>DataTrigger<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>Style<SPAN class="punctuation token">.</SPAN>Triggers<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>Style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ComboBox<SPAN class="punctuation token">.</SPAN>Style<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Do I need something to make it work or is that bug?
Best Regards,
Than
