I authored a simple check-in survey in Connect, with a date field set to a default value of "today()". However, when I publish and open the survey in the web application, the default date doesn't appear. Is this a limitation of the Connect to Web App translation?
I've noticed this in other surveys I've authored as well, however I thought it was due to republishing a survey after making changes. I deleted my check in survey and tried publishing it again, but the same error occurred.
Thank you,
Hilary
