Hi everyone, I have some WRF model output data in NetCDF format, and I would appreciate any guidance on projecting it from anyone with experience with data from this model. (WRF = Weather Research Forecasting)
These WRF runs use a Lambert Conformal Conic projection with a center of -121, standard parallels of 30 & 60 degrees North, and a latitude of origin of 45 degrees North. I think I have that figured out, but my data will be off if I don't use the right sphere/spheroid. My understanding is that WRF uses a sphere of 6370 KM with no flattening. Does this look right?
PROJCS["WRF_LCC_PacificNW",
GEOGCS["WRF_Sphere_6370km",
DATUM["<custom>",
SPHEROID["<custom>",6370000.0,0.0]
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]
PROJECTION["Lambert_Conformal_Conic"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-121.0],
PARAMETER["Standard_Parallel_1",30.0],
PARAMETER["Standard_Parallel_2",60.0],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Latitude_Of_Origin",45.0],
UNIT["Meter",1.0]
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
