Hi, my folder with the xlsform became corrupted and the files were lost. I was able to download all the files except the xlsform from survey123.arcgis.com. Is there a way to recover the xlsform from any of the other data or via ArcGIS Online?
Hi Brian, for the remaining survey that you cannot download, it may be best to open a Tech Support case so an analyst can look at the particulars of your environment in more detail.
Thanks Ismael,
I found that your suggestion works on 1 of 2 surveys I tried as well downloading using Survey123 Connect works but not in all cases. I didn't dive into find out what is different about these. The user recreated the Survey in her case because the xlsform didn't download. She didn't try a device but is a good option. Thanks.
Hi. If you still have the survey published in ArcGIS, you can recover the XLSFile as follows:
Alternatively, if you conserve a device with the survey, you can extract the file from your device as well.
