In ArcMAP 10.5 how to switch units from metric to Imperial? I have contours which are in metric and client wants it in imperial and export to AutoCAD
You do realize that the best that could happen is that the existing contour lines would just have the new units shown which would look a bit strange. Or does the client want the data reinterpolated to using inches as the contouring and labelling unit?
Also, how are the contours being labelled at present?
BTW 39.37 inches to the meter
I agree with Dan_Patterson, however, if you have the raster that the contours were created from you'd be able to change units by using the Z Factor on the tool.
