I have a feature layer with polylines, let's call it "polyline_layer". And there are already some polylines on this layer. Now I created a map tool that lets the user sketch a new polyline on that specific layer. So far so good, but I need to check whether the newly sketched polyline touches an existing polyline (so I can modify the existing polyline instead of creating a new one).. but when I call "GeometryEngine.Touches" to check whether two polylines touch an exception is thrown ("incompatible spatial references"). How can this happen? The new polyline has been sketched on the same layer that contains the existing polylines. The WKIDs of the spatial references are the same, but IsEqual returns false nonetheless. This seems a bit strange to me?!
If I project the sketched polyline into the spatial reference of the layer everything works fine, but it's stilll a bit weird. Here's some example code:
<SPAN class="keyword token">internal</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">CreatePolyline</SPAN> <SPAN class="punctuation token">:</SPAN> MapTool <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">public</SPAN> <SPAN class="token function">CreatePolyline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
IsSketchTool <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
UseSnapping <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
SketchType <SPAN class="operator token">=</SPAN> SketchGeometryType<SPAN class="punctuation token">.</SPAN>Line<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="comment token">/// <summary></SPAN>
<SPAN class="comment token">/// Called when the sketch finishes. This is where we will create the sketch operation and then execute it.</SPAN>
<SPAN class="comment token">/// </summary></SPAN>
<SPAN class="comment token">/// <param name="geometry">The geometry created by the sketch.</param></SPAN>
<SPAN class="comment token">/// <returns>A Task returning a Boolean indicating if the sketch complete event was successfully handled.</returns></SPAN>
<SPAN class="keyword token">protected</SPAN> <SPAN class="keyword token">override</SPAN> <SPAN class="keyword token">async</SPAN> Task<SPAN class="operator token"><</SPAN><SPAN class="keyword token">bool</SPAN><SPAN class="operator token">></SPAN> <SPAN class="token function">OnSketchCompleteAsync</SPAN><SPAN class="punctuation token">(</SPAN>Geometry geometry<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> sketchedPolyline <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>Polyline<SPAN class="punctuation token">)</SPAN>geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>sketchedPolyline <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>sketchedPolyline<SPAN class="punctuation token">.</SPAN>PointCount <SPAN class="operator token"><</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
FeatureLayer polylineFeatureLayer <SPAN class="operator token">=</SPAN> <SPAN class="comment token">//Get feature layer called "polyline_layer"</SPAN>
<SPAN class="keyword token">var</SPAN> geoEngine <SPAN class="operator token">=</SPAN> GeometryEngine<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//Uncomment the following lines to avoid the exception</SPAN>
<SPAN class="comment token">//var srLayer = polylineFeatureLayer.GetSpatialReference();</SPAN>
<SPAN class="comment token">//sketchedPolyline = (Polyline)geoEngine.Project(sketchedPolyline, srLayer);</SPAN>
<SPAN class="keyword token">var</SPAN> rowCursor <SPAN class="operator token">=</SPAN> polylineFeatureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">while</SPAN> <SPAN class="punctuation token">(</SPAN>rowCursor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MoveNext</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> polyline <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>Polyline<SPAN class="punctuation token">)</SPAN>rowCursor<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"SHAPE"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>geoEngine<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Touches</SPAN><SPAN class="punctuation token">(</SPAN>sketchedPolyline<SPAN class="punctuation token">,</SPAN> polyline<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//Do something..</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I'd be glad if anyone could look into it! Thanks in advance.
Best Regards
Christian
