Is it possible to set the default value of an integer field to NULL? I would like to set the relevance of the following question to show once the integer question is answered with a number >= 0.
Hi Brent,
By default, if an integer question is left blank, it should be given a value of 'Null'. Please let us know if you are encountering something different.
Brandon
Hi Brian,
Where are you experiencing this behavior? Is it when using the Survey123 field app, or Web Form? If using the field app, what version?
I have a similar issue. When the user clicks through to the next question using a "yes" or "no", but then backs out of that line of questioning, the blank integers that are in a required field are sent as zeros with the survey instead of staying null.
Is there something that can be done to prevent this from happening?
