Hi all,
Creating a multi ring buffer tool - it doesn't seem to be presenting with the layer at the end?
Has anyone else had this? Does anyone have a working example they can share?
I have even gone back to the basic buffer example in the samples and amended the two lines of code and I still get no layer:
protected override async Task<bool> OnSketchCompleteAsync(Geometry geometry)
var valueArray = await QueuedTask.Run(() =>
var g = new List<object>() { geometry, };
return Geoprocessing.MakeValueArray(g,"C:\ArcGIS\Projects\MyProject1\MyProject1.gdb\Annotation",@500,1000,2000,"Meters","Distance","All","None");
await Geoprocessing.ExecuteToolAsync("Analysis.MultipleRingBuffer", valueArray);
return true;
I have tried this in the new 2.1 SDK also to no avail.
I have a sneaky suspicion it has something to do with the buffer value syntax. Annotation is a feature class for polygons.
Buffer works absolutely fine and I have got it working in arcpy. However I want the user to be able to use the cursor to pick a point on the screen rather than have a feature class with points in to "multibuffer".
TIA
