Is there a way to include the feature's ObjectID in the MS Word tempate used for generating a report?
${ObjectID} does not seem to work. Thanks!
Hi Keith,
You may need to check the precise name of the Object ID field. For example, the field name or a survey published by Survey123 is objectid (all lower case), though the alias is 'ObjectID'. Therefore, ${objectid} should work in a template.
Thanks very much James, that worked!
Access the Database via MS Access. However does not work with File Geodatabase
Yes, of course I could do that, but that's not ideal. There's lot's of other hidden fields in there as well that I'd like to know how to access if there's a way to do that without duplicating all those with new fields just so I can print them.
My question remains - Is there a way to access these hidden field types like ObjectID using the correct syntax in the Word template?
Create a new attribute and populate it with ObjectID before generating the report
