I am making a survey in Survey123 Connect which I want the end user to consume in a web browser. It is a quite simple survey, but I need the functionality from the XLS-form in relation to building it in the web app. The problem I have is that when opening the published survey in a web browser it loses a lot of basic functionality. For example I can not collapse groups, they are always expanded with just the group name as a title. Furthermore some of the questions that has relevant expressions does not appear even though the criteria is met. The repeat formula does not work as expected either, since the questions are all lined up as for example three identical questions following eachother instead of them appearing one by one as you answer the question.
Is there any known discrepancy between building a survey in Connect and then consuming it in a web browser? How can I work around my problem?
