Hello everyone! we are going to use Survey123 for the first time in our environment, any specifications or special requirements for the Tablets on the field that will be used for collection? Thank you
Hi Jack,
I would say just get started with building a survey and do some quick on-site testing to get a good feel for it. Once you get more into it, you will have more specific questions in which you may be able to find quick answers to on GeoNet or other places.
You can watch this hour long video showing tips and tricks, but again, it may be best to initially get started, then start digging into the specific details later:
Survey123 for ArcGIS: Tips and Tricks - YouTube
Here is a PDF of the slideshow of the tips and tricks
http://proceedings.esri.com/library/userconf/devsummit17/papers/dev_int_181.pdf
Thank you Adrian, appreciate it. Yes, I did all this and during testing I used a regular laptop but we would like to use tablets on the field for this particular project, which includes more than 1300 houses.
Just called ESRI support and they are sending me a document with recommendation for hardware (amazing that I can't find a specific document anywhere online describing the devices used on the field for collection)
Thank you again, Jack
That's good to hear! If it is an easy-to-share link that Esri gives you, it would be helpful to share it here for others to see. If it is customized and/or tailored for you and your operation, then it would be ok not to share it publicly. And I agree that it's interesting that you are not able to find docs on specific devices - though this kind of document would be such a 'moving target' that it would be hard to keep it current and not look out-dated on the web.
Yes, but still should be some type of general recommendations – actually I was looking forward to this site for help from people who actually implemented the tool; not many responses, actually, only you, surprising!
If you want to take pictures as a major component of your surveys you may want to consider iPads. There is a Bug in Survey123 for android involving camera focus. There are work arounds and should be fixed eventually but is still a pain. I would also suggest getting a unit or 2 to test before purchasing a large number.
Thank you much Christopher for your response – do you know if the issue was resolved?
I believe (and hope) it will be addressed in the next update. If you do go Android stay with a mainstream device which will increase the likely hood of Esri having a one to test with if you need to call Tech Support.
Definitely!! Thank you so much, very helpful.
We have deployed 14 iPad Mini 2 in the field for data collection at natural gas well pads. 32GB memory wi-fi only with weather proof case. I would suggest an otter box or fre life proof case to ensure better water resistance.
We also have some field personnel using their own devices (Android phone, iPhone and Windows phone).
Good Luck,
--gary
