Is a way to set the Visibility Range and/or add a filter based on attribute values with a Feature Layer in ArcGIS Online using the ArcGIS Python API?
This code is great, but it's missing one piece. How did you define feature_layer_item? I'm just guessing to access this from the layers of a web map. But doing it this way sets the type of feature_layer to: arcgis._impl.common._mixins.PropertyMap, which is giving me an error of having no attribute manager, required in line 43.
Here is one way how you can do that for one service and it could give you idea how to implement the full process.
EDIT: Note that I understood that you want to change the range in the Feature Service level (and not override it later on the configuration stack ie. WebMap level). So this will change the values directly to the service endpoint level.
<SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>gis <SPAN class="keyword token">import</SPAN> GIS <SPAN class="keyword token">import</SPAN> getpass password <SPAN class="operator token">=</SPAN> getpass<SPAN class="punctuation token">.</SPAN>getpass<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Enter password: "</SPAN><SPAN class="punctuation token">)</SPAN> gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'https://cgisuomi.maps.arcgis.com/home'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'antti.kajanus_CGISuomi'</SPAN><SPAN class="punctuation token">,</SPAN> password<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Connected to: {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>gis<SPAN class="punctuation token">.</SPAN>properties<SPAN class="punctuation token">.</SPAN>urlKey <SPAN class="operator token">+</SPAN> <SPAN class="string token">"."</SPAN> <SPAN class="operator token">+</SPAN> gis<SPAN class="punctuation token">.</SPAN>properties<SPAN class="punctuation token">.</SPAN>customBaseUrl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Connected as: {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>gis<SPAN class="punctuation token">.</SPAN>users<SPAN class="punctuation token">.</SPAN>me<SPAN class="punctuation token">.</SPAN>username<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>features <SPAN class="keyword token">import</SPAN> FeatureLayer feature_layer <SPAN class="operator token">=</SPAN> feature_layer_item<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> feature_layer <SPAN class="comment token">#<FeatureLayer url:"https://services1.arcgis.com/ut5Ig3pyAO7DhCxU/arcgis/rest/services/HSLCityBikes/FeatureServer/0"></SPAN> <SPAN class="keyword token">import</SPAN> requests <SPAN class="keyword token">import</SPAN> json <SPAN class="comment token"># Get service content info</SPAN> request <SPAN class="operator token">=</SPAN> requests<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>feature_layer<SPAN class="punctuation token">.</SPAN>url <SPAN class="operator token">+</SPAN> <SPAN class="string token">'?f=pjson&token={}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>gis<SPAN class="punctuation token">.</SPAN>_con<SPAN class="punctuation token">.</SPAN>token<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> service_layer_json <SPAN class="operator token">=</SPAN> request<SPAN class="punctuation token">.</SPAN>json<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#Check current scale range</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MinScale = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'minScale'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MaxScale = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'maxScale'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># MinScale = 1155582</SPAN> <SPAN class="comment token"># MaxScale = 0</SPAN> <SPAN class="comment token">#Update scale range</SPAN> service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'minScale'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">15000</SPAN> service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'maxScale'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">150</SPAN> <SPAN class="comment token">#Check new scale range</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MinScale = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'minScale'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MaxScale = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'maxScale'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># MinScale = 15000</SPAN> <SPAN class="comment token"># MaxScale = 150</SPAN> <SPAN class="comment token"># Apply edits to the service</SPAN> <SPAN class="comment token"># Make sure that url is not in the properties</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="string token">'editingInfo'</SPAN> <SPAN class="keyword token">in</SPAN> service_layer_json<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">del</SPAN> service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'editingInfo'</SPAN><SPAN class="punctuation token">]</SPAN> result <SPAN class="operator token">=</SPAN> feature_layer<SPAN class="punctuation token">.</SPAN>manager<SPAN class="punctuation token">.</SPAN>update_definition<SPAN class="punctuation token">(</SPAN>service_layer_json<SPAN class="punctuation token">)</SPAN> result <SPAN class="comment token"># {'success': True}</SPAN> <SPAN class="comment token"># Testing that changes have been applied</SPAN> feature_layer_item <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'96d90824c0b94025abefeb7fe0ef60a0'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Get service content info</SPAN> request <SPAN class="operator token">=</SPAN> requests<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>feature_layer<SPAN class="punctuation token">.</SPAN>url <SPAN class="operator token">+</SPAN> <SPAN class="string token">'?f=pjson&token={}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>gis<SPAN class="punctuation token">.</SPAN>_con<SPAN class="punctuation token">.</SPAN>token<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> service_layer_json <SPAN class="operator token">=</SPAN> request<SPAN class="punctuation token">.</SPAN>json<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#Check current scale range</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MinScale = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'minScale'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MaxScale = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>service_layer_json<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'maxScale'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># MinScale = 15000</SPAN> <SPAN class="comment token"># MaxScale = 150</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
