I have a related table setup like the example, I also have a feature data grid setup that works with my basic spatial and attibute selection and I noticed when I click on a APN (item) in the tree - it also selects or highlights the layer in FDG. I want to two way bind my tree so when I select a item in my FDG it selects the item in my tree. Can you help me with this?Resources - XAML (MY RESOURCE for my tree)
<!-- RELATED LINK RESOURCE-->
<common:HierarchicalDataTemplate x:Key="TreeViewItemTemplate">
<StackPanel Orientation="Horizontal" Margin="0">
<!--<Ellipse Fill="Transparent" Height="6" Width="6" StrokeThickness="2" Stroke="Black" Margin="0,0,10,0"/>-->
<TextBlock Text="APN: " HorizontalAlignment="Left" FontSize="10" Margin="0"/>
<TextBlock x:Name="TextBlockRelate" Text="{Binding Attributes[APN], Mode=TwoWay}" HorizontalAlignment="Left" FontSize="10"/>
</StackPanel>
</common:HierarchicalDataTemplate>
<!--END RELATED LINK RESOURCE-->XAML MY TREE AND FDG FOR RELATED RECORDS
<userControls:DraggableWindow x:Name="RelateResultsDisplay" IsOpen="False"
VerticalAlignment="Bottom" HorizontalAlignment="Right"
Margin="15" Effect="{StaticResource dropShadow}" Title="RELATED WORK RESULTS TABLE" Background="Black">
<Grid HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Width="Auto" Height="Auto" >
<Border Effect="{StaticResource miniDropShadow}" Style="{StaticResource RibbonElementBorder}" Padding="15" Margin="10">
<Grid x:Name="RelatedRowsGrid" HorizontalAlignment="Right"
VerticalAlignment="Top" MinHeight="170" Width="Auto">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="140" />
<ColumnDefinition MaxWidth="600" />
</Grid.ColumnDefinitions>
<StackPanel Orientation="Vertical" Margin="1,-5,1,5">
<TextBlock Margin="1,0,5,1" TextWrapping="Wrap" Grid.Column="0"
Text="Click to see relates: "
FontSize="10" FontFamily="Arial" Foreground="#FFFFFFFF" />
<basics:TreeView x:Name="SelectedWellsTreeView" MaxHeight="180" Grid.Column="0" Margin="1"
ItemsSource="{Binding}" BorderBrush="Gray" BorderThickness=".5"
SelectedItemChanged="SelectedWellsTreeView_SelectedItemChanged"
ItemTemplate="{StaticResource TreeViewItemTemplate}"
</StackPanel>
<esriWidgets:FeatureDataGrid Grid.Column="1" Grid.Row="1" x:Name="MyFDG" Height="180"
Style="{StaticResource FeatureDataGridRelateStyle1}" MouseLeftButtonUp="MyFDG_MouseLeftButtonUp"
</Grid>
</Border>
</Grid>
</userControls:DraggableWindow>MY XAML FOR MY SELECTION FDG - THE ONE I WANT TO SELECT A ROW/RECORD HERE AND HAVE IT SELECT MY CORRESPONDING TREE ITEM AND SHOW THE RELATED RECORDS
<userControls:DraggableWindow x:Name="ResultsDisplay" IsOpen="True"
Margin="15" Effect="{StaticResource dropShadow}" Title="RESULTS TABLE" Background="Black">
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="15" />
<RowDefinition Height="*" />
</Grid.RowDefinitions>
<TextBlock x:Name="DataDisplayTitle" Text="Search Results" FontSize="9" Grid.Row="0" FontWeight="Bold" FontFamily="Arial" Foreground="#FFFFFFFF" />
<esriWidgets:FeatureDataGrid Grid.Row="1" x:Name="QueryDetailsDataGrid" Height="170"
Map="{Binding ElementName=Map}"
GraphicsLayer="{Binding Layers[MySelectionGraphicsLayer], ElementName=Map}" Style="{StaticResource FeatureDataGridStyle1}" MouseLeftButtonUp="QueryDetailsDataGrid_MouseLeftButtonUp" SelectionChanged="QueryDetailsDataGrid_SelectionChanged"
</Grid>
</Border>
</Grid>
CODE BEHIND
private void SelectedWellsTreeView_SelectedItemChanged(object sender, RoutedPropertyChangedEventArgs<object> e)
if (e.OldValue != null)
Graphic g = e.OldValue as Graphic;
g.UnSelect();
g.SetZIndex(0);
if (e.NewValue != null)
Graphic g = e.NewValue as Graphic;
g.Select();
g.SetZIndex(1);
//OBJECTID, PARCELID, X_COORD, Y_COORD, APN, ADDRNMBR, ADDRNAME, GEN_PLAN
//Relationship query
RelationshipParameter relationshipParameters = new RelationshipParameter()
ObjectIds = new int[] { Convert.ToInt32(g.Attributes[SelectedWellsTreeView.Tag as string]) },
OutFields = new string[] { "*" },
RelationshipId = 0,
OutSpatialReference = Map.SpatialReference,
queryTask.ExecuteRelationshipQueryAsync(relationshipParameters);
relateIDstring = g.Attributes["APN"].ToString();
// MessageBox.Show(g.Attributes["OWN_ADDR1"].ToString());
// MyFeatureDataForm.GraphicSource = g;
void QueryTask_ExecuteRelationshipQueryCompleted(object sender, RelationshipEventArgs e)
// This line gets you the all features returned from the Relationship Query
// IEnumerable<Graphic> graphics = e.Result.RelatedRecordsGroup.First().Value;
RelationshipResult pr = e.Result;
if (pr.RelatedRecordsGroup.Count == 0)
l.Where = "1=0"; //remember _featureLayer is l
// RelatedRowsDataGrid.ItemsSource = null;
else
foreach (var pair in pr.RelatedRecordsGroup)
// RelatedRowsDataGrid.ItemsSource = pair.Value;
// MyFDG.ItemsSource = pair.Value;
// MyFDG.ItemsSource = pair.Value.Select(graphic => graphic.Attributes);
// There are two ways to filter either using Where clause or using the ObjectIDs property
// before you set the Where clause to return all records 1=1 I think
// Here instead lets use the ObjectIDs approach, first get rid of the old Where
l.Where = null; //remember _featureLayer is l
//ObjectIDs takes an int[] and with a little Linq we can get that array
// I am assumning you have included OBJECTID in your outfields when you defined the query
int[] objectIds = graphics.Select(g => (int)g.Attributes["OBJECTID_1"]).ToArray();
//now set the ObjectIDs on our FeatureLayer
l.ObjectIDs = objectIds;
//Update the FeatureLayer to 'redraw' the new filtered set of Features
l.Update();
//And I hope this worked. you could rebind the layer to the grid to make sure all is good
MyFDG.GraphicsLayer = l;
MyFeatureDataForm.FeatureLayer = l;
// MyFDG.Resources["SeeRelateButton"].Visibility = Visibility.Visible;
#endregionUNTIMELY I WOULD LOVE TO JUST REMOVE THE TREE VIEW LIST AND JUST USE MY FDG (2nd one name QueryDetailsDataGrid) because right now a user does a selection it populates the QueryDetailsDataGrid and then she/he opens the related tree and selects the item to populate and see the related records. I would rather just skip over the tree list and just have the user select one record in the QueryDetailsDataGrid and have that retrieve the related records. But I can't get it to work that way.Thanks Nathalie
