Can you please take a look at this example and let me know how to I can replace Data Source data of a layer in a saved mxd map (Fuse) to a layer called SDEElectric.DBO.Fuse which is in an enterprise geodatabase through database connection
I tried this code but it didnt work
<SPAN class="keyword token">import</SPAN> arcpy
mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"C:\GIS\Maps\Electric.mxd"</SPAN><SPAN class="punctuation token">)</SPAN>
src <SPAN class="operator token">=</SPAN>r<SPAN class="string token">"C:\Users\xyz\AppData\Roaming\ESRI\Desktop10.4\ArcCatalog\SDEElectric.sde\SDEElectric.DBO.Dataset\SDEElectric.DBO.Fuse"</SPAN>
df <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> df<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Fuse"</SPAN><SPAN class="punctuation token">:</SPAN>
lyr<SPAN class="punctuation token">.</SPAN>replaceDataSource<SPAN class="punctuation token">(</SPAN>src<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"FILEGDB_WORKSPACE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN
