What is M-Resolution and what affect does this setting have on M Values? Everything I read says "M-Resolution should be the M-Tolerance divided by 10". Is the M-Resolution the number of M-Values between the minimum M value and the next (i.e. Implies using BASE10)? Maybe it means that if you have a long mile then it can insert an additional 10 M values between each existing M?
I understand M-Tolerance to be: If x and y coordinates are coincident and their m-values are within the M-Tolerance range then their M-values should be set equal to one another.
Typical M Resolution and Tolerance Settings:
