Hi
A Geometry object has a 'touches' method, but it doesn't appear to work.
I have a given polygon, and have tested with polylines that are a) contained fully within, b) cross over the perimeter of and c) are completely outside, and all scenarios return a false result. I get this result whether I call geometry1.touches(geometry2) or geometry2.touches(geometry1).
To further confirm, if I call geometry1.within(geometry2) then I get the expected results of false if geometry1 is outside geometry2 or partially outside, and true if it is fully inside. I would expect that a geometry "within" therefore definitely "touches".
I also tried geometry.touches(geometry), assuming that this would return true because the two parameters are exactly the same but still got a false result.
As a workaround, I can use the intersect method and test whether it is valid:
if (geometry1.intersect(geometry2).valid){ //do something }Can anyone else confirm whether the "touches" method is working for them or not?
Cheers,
-Paul
