I have the same error.
I met the same problem when I try to install ArcGIS for AutoCAD 400 on WIN 10 PC for AutoCAD 2021 or 2020. But it succeeded on other PC . Check the Registry of My Win 10 , no obvious Problems as showing on the Internet, such as this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1606-when-installing-2014-product.htmlHow to solve it?NEED HELP by My gmail: donlyliu@gmail.comTHANKS!
Exact same situation with me.
You might check to see if you have access to an ApplicationPlugins folder. We did see some users in beta where that folder wasn't available and therefore the install is failing.
Here's a more complete answer from a draft of a knowledgebase article about to be published:
TitleProblem: "Error 1606: Could not access the network location" encountered when attempting to add the installation of ArcGIS for AutoCAD 400Edit Title
DescriptionWhen installing version 400 of ArcGIS for AutoCAD, you encounter the error.CauseArcGIS for AutoCAD is installed into the %ProgramFiles%/Autodesk/ApplicationPlugins folder. If this folder is missing or not accessible by the current user, ArcGIS for AutoCAD cannot be installed
Solution
There are two workarounds:1. Recommended: Reinstall AutoCAD to recreate the folder. OR,2. Create a new folder titled “ApplicationPlugins” in the %ProgramFiles%/Autodesk (this may have unintended consequences when installing and uninstalling AutoCAD plugins)
