I have 19 GB LAS-tiles that I want to convert to 1 DTM and 1 DSM using the LAS to Raster Conversion tool. The tool is running but dit not process anything (aborted at 0% processed after 20 hours without any error Messages). All environment variables is set. Any tip?
Thanks Dan!
Best to you as well Frank...
Thanks Dan, I will consider the Tile-Las tool.
When I use a Linear Void fill Method (Binning) and integer output the Processing worked well (quite fast, app 3 minutes With a 0.5 cell-size). After some googling I realised that the Natural_Neighbour Void fill Method is consuming a lot of Resources when Processing big amounts of data.
Wish you a Merry Christmas!
Best regards,
Frank
probably gave up given the size... have you considered...
http://desktop.arcgis.com/en/arcmap/latest/tools/3d-analyst-toolbox/tile-las.htm
but not in modelbuilder, try a test manually to see where the break point is first.
