I would like to change the "Other" text label in the select_multiple [list_name] and "Specify other" because I need to put them in Spanish. Any help? Thanks in advance! 🙂
Hi Sergio. I am attaching here an XLS file to show how to do what you are looking for. Essentially, you need to manually add a question so you can persist the value of 'other' and also add a relevant statement to make sure your 'other' question only shows when the 'other' option has been chosen in your list. A lot of people get trapped into thinking that the expression is something like ${SportsLiked} = 'other', but the best expression is selected(${SportsLiked},'other'). In this way, the 'other' question will show every time you check the 'other' option. It will all make sense when you have a look at the XLS file attached. It is quite simple. I know this is a bit more complex than simply adding 'or other' after your select_multiple question... the shortcut only works in English....
Thank you very much for your help, Ismael!
