I have noticed that when you create a copy of a survey from the Sent box the repeats for the original survey are removed. Is this the software design for how repeats are managed within the Sent box?
Below is the example of the workflow I am using.
- Create original survey with a repeat.
- Look at the survey data in the hosted service for the original survey. The repeat is there.
- Create a copy of the original survey from the Sent box.
- Look at the survey data in the service. The original survey has no repeat record. The copy does of the repeat record.
This removes the history of capturing repeats for previous surveys. What is the reason for removing the repeats for the original survey?
Thank you,
Kevin
