Hi, I'm developing an arcgis pro configuration and I would like to use entity framework
to access an Oracle database.
I always get the error "No connection string named 'xyz' could be found in the application
config file." Is it possible to use entity framework in a "configuration" project? Thanks in advance!
code:
using (var context = new Entities())
var user = new APPL_USERS()
ID_USER = 1,
NAME = "aaa",
COUNTRY= "bbb"
context.APPL_USERS.Add(user);
context.SaveChanges();
app.config
<oracle.manageddataaccess.client>
<version number="*">
<dataSources>
<dataSource alias="aaa" descriptor="(DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=xyz)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=SRV_xyz))) " />
</dataSources>
</version>
</oracle.manageddataaccess.client>
<connectionStrings>
<add name="OracleDbContext" providerName="Oracle.ManagedDataAccess.Client" connectionString="User Id=oracle_user;Password=oracle_user_password;Data Source=oracle" />
<add name="Entities" connectionString="metadata=res://*/Model1.csdl|res://*/Model1.ssdl|res://*/Model1.msl;provider=Oracle.ManagedDataAccess.Client;provider connection string="DATA SOURCE=aaa;PASSWORD=xyz;PERSIST SECURITY INFO=True;USER ID=TEST"" providerName="System.Data.EntityClient" />
</connectionStrings>
