So the API has a where option and a setWhere method with other time filter methods.
L.esri.Layers.FeatureLayer | Esri Leaflet
Is there a way to set the geometry as well? Right now it uses the bounds of the map to limit queries, but can I override that pretty easily somewhere?
Right now I can jump through some hoops using Turf to do point-in-polygon searches, but it doesn't work if I need to check points outside the bounds of the map not queried yet.
Turfjs/turf-inside · GitHub
I'm thinking I could just query the data on my own, convert to GeoJSON and use Turf + properties filtering to search my results, but was kind of hoping there was a workflow in Esri-Leaflet already to do this. Any ideas?
Thanks.
