I'm using the Esri Angular CLI template from Github here: GitHub - Esri/angular-cli-esri-map: Example Angular component for building mapping applications with the ArcGIS API for … . I've been trying to understand how I can add a widget to the app, in the esri-map.component.ts file. I've added the appropriate code for the BasemapToggle widget within the "async ... try {..." and after the "const mapViewProperties:..." parts like so:
But after that, I get a window in Visual Studio Code saying "any: Property 'add' does not exist on type 'DefaultUIProperties'", even though it looks like add() is mentioned in the documentation: https://developers.arcgis.com/javascript/latest/api-reference/esri-views-ui-DefaultUI.html.
The code is attached. Any guidance whatsoever would be greatly appreciated.
As the mentioned reference is added, I still can't find the solution
Maybe this response will help others....
Add the widget to the mapview in the mapView.when(() => { callback. This will ensure that the mapView is fully initialized AND in scope.
