Dear Community,
I am using ArcGis for Desktop 10.3.1. I am trying to run Model Builder using Iterate Feature Selection and Summary Statistics. I get Error 000210 "Cannot create output" and don't know what is wrong. I am doing it for the first time. Maybe there is something that I miss? I changed the Default geodatabase for another goedatabase that I created.
Any advises?
Thank you,
Iga
Ok, I changed it but the effect is that I have now 600 tables named by the FID (Value) and each contains one record with result.
Just to be sure: so you have a the file geodatabase Siechnice.gdb and it contains a feature dataset called "iterate" and you are trying to create a table called "1" inside this feature dataset "iterate":
A feature dataset cannot contain tables, so by default the output table specified is invalid. Remove the last "\" just before %Value% to create a table with the name "iterate1" instead.
I am sure it exists. Maybe there is some other mistake?
I assume that "D:\Iga\dane\dane_model\Siechnice.gdb\iterate\1" does not exist. Can you show how you configured the tool in modelbuilder?
Help on the topic van be found here: Examples of using iterators in ModelBuilder—Help | ArcGIS Desktop
