I am trying to use the analysis tool overlay_layers. Because my dataset is so large I am querying it so I have two FeatureSets. This tool requires FeatureLayers so I am using the information from here to have feature collections but when I run the overlay tool I get an error.
Many thanks to any feedback
Here is my code:
#checking I have FeatureCollections
type(fc1)
arcgis.features.feature.FeatureCollection
type(fc2)
#Running the analysis
overlay_rf = overlay_layers(input_layer=fc1, overlay_layer=fc2, overlay_type='Intersect')
And here is the error I get:
---------------------------------------------------------------------------JSONDecodeError Traceback (most recent call last)<ipython-input-30-4a4a1668cec5> in <module>----> 1 overlay_rf_subfacet = overlay_layers(input_layer=wdpa_fc, overlay_layer=facet_fc, overlay_type='Intersect')~/anaconda3/lib/python3.7/site-packages/arcgis/features/manage_data.py in overlay_layers(input_layer, overlay_layer, overlay_type, snap_to_input, output_type, tolerance, output_name, context, gis, estimate) 191 output_name, 192 context,--> 193 estimate=estimate) 194 195 def create_route_layers( ~/anaconda3/lib/python3.7/site-packages/arcgis/_impl/tools.py in overlay_layers(self, input_layer, overlay_layer, overlay_type, snap_to_input, output_type, tolerance, output_name, context, estimate) 1529 1530 -> 1531 task_url, job_info, job_id = super()._analysis_job(task, params) 1532 1533 job_info = super()._analysis_job_status(task_url, job_info)~/anaconda3/lib/python3.7/site-packages/arcgis/_impl/tools.py in _analysis_job(self, task, params) 143 params["f"] = "json" 144 --> 145 resp = self._con.post(submit_url, params, token=self._token) 146 #print(resp) 147 return task_url, resp, resp['jobId']~/anaconda3/lib/python3.7/site-packages/arcgis/_impl/connection.py in post(self, path, postdata, files, ssl, compress, is_retry, use_ordered_dict, add_token, verify_cert, token, try_json, out_folder, file_name, force_bytes, add_headers) 1141 resp_json = json.loads(resp_data, object_pairs_hook=OrderedDict) 1142 else:-> 1143 resp_json = json.loads(resp_data) 1144 1145 ~/anaconda3/lib/python3.7/json/__init__.py in loads(s, encoding, cls, object_hook, parse_float, parse_int, parse_constant, object_pairs_hook, **kw) 346 parse_int is None and parse_float is None and 347 parse_constant is None and object_pairs_hook is None and not kw):--> 348 return _default_decoder.decode(s) 349 if cls is None: 350 cls = JSONDecoder ~/anaconda3/lib/python3.7/json/decoder.py in decode(self, s, _w) 335 336 """--> 337 obj, end = self.raw_decode(s, idx=_w(s, 0).end()) 338 end = _w(s, end).end() 339 if end != len(s):~/anaconda3/lib/python3.7/json/decoder.py in raw_decode(self, s, idx) 353 obj, end = self.scan_once(s, idx) 354 except StopIteration as err:--> 355 raise JSONDecodeError("Expecting value", s, err.value) from None 356 return obj, end JSONDecodeError: Expecting value: line 1 column 1 (char 0)
