Hello everyone,
When creating an SDE View in ArcSDE 10.4 between a FC and a table. How is the field OBJECTID used?
- ignore it and create the SDE view without it. This solution does not work well
- add the OBJECTID from the FC
- add the OBJECTID from the table
The OBJECTID field in a SDE View is a long integer not an OBJECT ID type. So when I copy the SDE view to another Geodatabase it adds a new field OBJECTID_1 in the new feature class, this one has data type Object ID.
Environment:
- ArcSDE 10.2 Oracle
- ArcSDE 10.4 SQL
Until ArcGIS 10.2 we created SDE Spatial views with the command line, and they worked fine:
sdetable -o create_view -T ProjectInfo -t "Project, Project_Table"
-c "Project.SHAPE, Project.OBJECTID, Project.ProjectID, Project_Table.DATEOFFERED, Project_Table.DATEEXECUTED, Project_Table.Project_STATUS,Project_Table.PROJECTNAME"
-a "SHAPE, OBJECTID, ProjectID, DateOFFERED, DateEXECUTED,STATUS, PROJECTNAME" -w "Project.ProjectID IS NOT NULL AND Project.ProjectID = Project_Table.ProjectID"
Now in ArcGIS 10.4 we are creating SDE Spatial Views directly in ArcCatalog and the OBJECTID field has some issues
CREATE VIEW ProjectInfo AS SELECT Project_Table.OBJECTID, Project.SHAPE, Project.ProjectID, Project_Table.ProjectSTATUS AS STATUS ,Project_Table.DATEOFFERED, Project_Table.DATEEXECUTED, Project_Table.PROJECTNAME FROM Project INNER JOIN Project_Table ON Project.ProjectID = Project_Table.ProjectID WHERE (NOT (Project.ProjectID IS NULL))
