I am adding an ArcGISDynamicMapServiceLayer layer on run time in to a Web appbuilder application. So far I am able to manipulate/change the title and name of the layer on the legend widget but not the labels (marked in black)
If you log the layerInfoParam.layer you can clearly see that the label is part of the legendResponse object (line 151), but trying to access this object results in to "undefined". Any idea why?
The alternative to use esriRequest and fetch the legend object in json looks not a lightweight task so not an good option.
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>layerInfoParam<SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
