I built a model in which an output feature class is generated from the Merge tool. ModelBuilder automatically sets this output parameter to a Required Input parameter that shows up when the user runs the tool from the tool dialog box. This is supposed to be an Output parameter, so should not require the user to supply it via the tool dialog. Is there any way to tell ModelBuilder to make it a Derived instead of Required parameter?
